Connecting to COD
TFC
Connecting to COD
Sorry if this is in the wrong place, but as it relates to COD servers I thought it the best place to start.
I have just installed a new Netgear DG834G router, upgraded to latest firmware. when I select a server the splash screen "Loading COD" comes up and sits there for upwards of 90 secs, the program then loads and all is well. It just seems to take ages, and I have found that it has caused the loss of a server slot.
I use ASE to connect.
Prior to today, I was using a Conexant (sp) PCI ADSL modem, this loaded the game almost instantly.
Has anyone knowledge of this Netgear router, is there anything I can adjust to remove this delay.
Cheers
Tom
Phantom_Flan_Fl
Connecting to COD
Can't help you personally mate, but you could try these COD specific websites here or here.
TFC
Connecting to COD
Thanks Dave I'll take a look.
I've been messing about changing the system back and forth... if I use the PCI modem, the games loads almost instantly... I'm fairly sure it's an issue with the router and not the game.
Tom
