Civ3 conquest
Civ3 conquest
Getting some problems connecting to hosts, firewalls are all off, could it be that plusnet is blocking some of the ports?? these are the ports it needs.
    6667
    3783
    27900
    28900
    29900
    29901
    13139
    6500
    2302
    13139
    6500
    2302
    2302
    13139
    6500
    2302
ne help would be great. O btw I am using a sar110 router
1 REPLY
jberry
Civ3 conquest
On your account only 2 ports are blocked, port 135 and port 445 (for antivirus purposes) so I cannot see this being the problem. I would guess this is a router setup issue. Make sure you have forwarded the correct ports and also that you have forwarded the correct type of traffic (TCP or UDP) for each of the ports.
Regards,
