Call of Duty Problem
I'm having trouble getting the multiplayer version of COD started at all. It's just sticking at the splash screen. Now single player works fine and multi used to start fine before we had broadband installed.
I've set my firewall to allow the required port access. I'm using a Netgear DG384G router.
Anyone got any clue why?
Would the developer version of DirectX be a problem? i can get every other game working fine with it.
Cheers
1 REPLY
yup, i have the same router and the same problem. The only way i get it 2 work is single player, then choose multiplayer on the main option screen. I havent had to open any ports to play though.
