CS help
CS help
I already update CS to 1.5. But when i click play on net,i can not join any server.Anyone can help me for adsl setting?
1 REPLY
RE: CS help
What does it say when you can't connect?
Have you updated Half-Life to the most recent version ?
Did you get the CS 1.5 Full Mod Version or did you upgrade from an earlier version ?
As far as settings go all you need to change is the tab on the server list to Dsl, but thats about it.
The wise man mocks the mocked, The mocked man mocks the mocker.....
