CS:S Stats.
CS:S Stats.
How does the stats thing work exactly? I went to http://cssource.frag9.net/stats/ to see if I could see my stats from the server 212.159.6.225:27015, but my username didn't appear there in the list of players, and I'm not really sure how I sign up to login. I did try doing ps_password [PASSWORD], but it just said unknown command.
Help?! :?
CS:S Stats.
Basically, the thing that generates the stats has a plugin to the server which currently doesn't work with CS:S so therefore you cannot perform the
'ps_' commands. You may not be shown on the stats because the stats have not been updated recently enough to show you.
Hope I helped!
CS:S Stats.
Thanks, it helped a lot! Cheesy
Does anyone know when the stats will be updated?
