CS Password ?
CS Password ?
The list gives 3 servers for counter strike
Counterstrike #1 - 212.159.6.215:27015
Counterstrike #2 - 212.159.6.216:27015
Counterstrike #3 (RaH) - 212.159.6.219:27015
I have tried and the first two do not seem to be there and the third will not let me in without a password?
Could someone please assist? e.g. with the password.
In addition, I have now noticed that the list is dated May 2003 so I please say if I am looking in the right place here?
jberry
CS Password ?
If you are looking at the post at the top of the forums then you are looking in the correct place - it was originally posted in may 2003 but has been updated many times since then (you just can't see the (Edited X Times) bit).
All three CS servers should be up and running - and should not be passworded for more that an hour or so a day. I will have a look and get back to you.
Regards,
CS Password ?
Any update on this?
Occasionaly the third server (RaH ?) is there but mostly not, and never any of the other servers ever seem to be there?
jberry
CS Password ?
How are you trying to view them? I can see them fine using ASE and can connect to them.
Regards,
CS Password ?
I have just checked and the third one (labelled RaH) is the only one there.
It could be me of course, I just go in to CS and then do add server in the favourites tab.
What is ASE? I don't seem to be able to fit that acronym in any place.
CS Password ?
All Seeing Eye. It's a program which allows you to view game servers, check their pings, etc. without actually having to go in-game and use that browser. Then you just double click on the server you want to join and it does the rest.
CS Password ?
Could I just confirm with someone.
I am playing the game (Counterstrike from steam), i.e. I am not running the server just connecting to plusnet servers as a client.
So I do not expect to have to do any port fordwarding or anything else on my router?
Is that correct?
CS Password ?
You are correct - as a player you do not need to forward any ports.
CS Password ?
It's official.
It turns out that the first 2 CS servers on the list are not working.
CS Password ?
And still not working, I don't play that often, but I do wonder why when I try to play, the servers have a problem or are lockedHuh?, am I paying for RAH clans server , if so I want to use it.
jberry
CS Password ?
You are not paying for their server - it is provided for free. They get to use the server for doing the significant amount of administration work that is necessaty to keep a server is use.
This means that from time to time the server will be locked down, although if this is all the time then please let me know and I will get in touch with them.
Regards,
CS Password ?
The RAH server has been locked for the past 3 days, and the 212.159.6.216 server isn't responding.
CS Password ?
CS Password ?
Yep Shockedops:
jberry
CS Password ?
I'll get in touch with the guy that runs it. Thanks.
