Best Modem/Router
Best Modem/Router
Hi Again
After finally sussing out what i need to get in order to have my PS2 and PC hooked up to the ADSL (with alot of help from the folk on here, cheers) I was wondering what the best router/modem would be to replace my USB Voyager 105 modem.
In the blue corner theres the Netgear DG834G 54Mbps Wireless ADSL Modem Firewall Router with 4-port 10/100 switch (heard alot of good things about it)
In the red corner there is the BT Voyager 1500 (i thought sticking with a BT product might mean its a better chance of all working to plan)
Cheers
Neil
Best Modem/Router
Forget the last post
Voyagers not even got a modem.
Time for bed me thinks
Cheers
iainmacmillan
Best Modem/Router
Any of the Netgear's are good, just upgraded my 834 std non-wireless to a 834PN, with the cool blue 7 wireless aerial dome......reroutes blocked signals. has 108Mb capability (54Mb each way) with the new RangeMax cards.
Best Modem/Router
Go with Netgear any time if i were you, been using my DG834G solidly now for 2 and a half years now and it is awesome.
Best Modem/Router
I'd agree - got a Netgear DG834G sat here running spot on - had a wired Netgear before - again with no problems.
