Battlefield: Vietnam movie making
Does anyone know how to make a little movie in BF:V, such as the demoing in half life? or do I need to use something like fraps (which i am loathe to do because it kills the frame rate). Any help would be greatly apreciated.
Windows does a recorder. Windows Media Encoder.
Latest Version is 9, it needs Direct X 9 to be installed as well. You can change the settings however i found it caused me to lag at times.
As well as recording to a hard drive, you can also broadcast live over the internet. Best if you and and the person viewing have broadband.
I broadcast through a router and it took me time to get the settings right. However once it was set up it worked fine.
Cheers
