A Broadband Modem for Xbox live
Can anyone advise what is the best broadband modem/router for Xbox live. I know the one i've got at the moment doesn't work so i'll buy a new one.
Some people on other forums have advised me to get the Netgear DG834. Does anyone use this modem with Plusnet to connect to Xbox live. I am looking to use the Direct Connection method.
Yep i have the dg834g wireless net gear router. Its great perfect for xbox live
If you buy a router, I'd suggest one with an in-built ADSL modem. However, they all pretty much work the same, so it comes down to how you want to use it and what for.
Routers
If you have XBox 360 with the Microsoft wireless adapter, cosider using a dual band (a/g) router. Linksys and Netgear have such products
Routers
