wifi drop out
Purplecat
wifi drop out
Hi all,
my router drops out constantly, at least 4/5 times a day and thats only when i'm home as I work full time.  Any advice please?
5 REPLIES 5
Fixes: 374
Re: wifi drop out
Is it your router or Wi-Fi signal which is the problem?
Purplecat
Re: wifi drop out
pretty sure it's router as tv is affected and that's wired in
Fixes: 374
Re: wifi drop out
OK, @Purplecat In that case, as it is most likely a network issue, can you please follow the below. May give other Community members an idea of the issue/possible solution.
For Community members to be able to help, information from these two sites, as screenshots:-
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (ethernet) connection. Please report the 'ADDITIONAL DIAGNOSTICS', and sight of the HELP DESK tab from your Hub would be a start.
adamwalker
Fixes: 223
Re: wifi drop out
Hi @Purplecat
I've just checked over your account and ran some line tests and we're not seeing signs of any obvious causes for the issues you've been seeing. Could you try following the checks shown here as your next step please?
 Adam Walker
Fixes: 374
Re: wifi drop out
@Purplecat Is this issue resolved?
