when does full fibre speed show?
Gus
Is the BT train in time still a thing for a new connection? I just upgraded to full fibre 500 and getting 215-225mbs so half of expected, so wondering if the BT 10 days wait time for true speed to show is still a thing or not.
FTTP 500 regrade from Tues 28th November
8 REPLIES 8
Fixes: 558
Re: when does full fibre speed show?
@Gus there is no training time for FTTP ( there never really was for FTTC! )
Is that speed test wired or wireless ?
Do you have any homeplugs(powerlines) in the circuit ?
Which router are you using ?
Gus
wireless, wi-fi card is capable of 1gigbit from the B650 AORUS ELITE AX
No home plugs
using the Hub2
Fixes: 558
You need to do a wired test to check
RealAleMadrid
Fixes: 68
@Gus  The only valid speed test for any broadband is via an ethernet connection to the router. Forget wi-fi it's meaningless, you are testing the wi-fi speed not your broadband connection.
markhawkin
Aspiring Champion
Fixes: 20
@Gus
The "real" speed of WiFi is much less than the theoretical maximum.
Buy a long Ethernet cable for your B650 AORUS ELITE AX and try the speed test using that.
Also the Plusnet supplied router isn't the greatest in terms of WiFi performance.
Once you have proved to your satisfaction that the connection is capable of the package speed you need to think where to go next.
For many people a mesh WiFi system helps. Look for WiFi 6E.
The ideal is using an Ethernet cable.
Assuming that's not practical, you have a capable computer and your next investment probably needs to be in a better WiFi system.
You might be able to optimise WiFi Performance by some adjustments of the position of the connected antenna on your motherboard but if you are more than 2m or a wall away from the router performance starts to drop.
pjmarsh
Fixes: 24
Just to expand a bit on what others have said, your motherboard has Wifi 6E, which could be capable of 1GB wifi, but the Hub2 only has Wifi 5 would in the real world will top out around the 200Mb - 300Mb range.
Gus
got a cat5e twisted pair 15m cable coming with plans on getting from router to living room wire nicely.  I just didn't know about the router limited to 300 at most so expected better
Gus
finally got a cat5e up and working
https://www.thinkbroadband.com/_assets/speedtest/button/1702638840663867455.png
fast enough for me
