upgrading to fibre 74
Fixes: 334
Re: upgrading to fibre 74
So, you appear to be on the (very old) ADSL product, in which case your current router will not work with Full Fibre, and does need replacing.
Fixes: 87
@Pete-21
You didn't state which router you actually have. If you have a Hub1 it will work with Full Fibre but performance will tail off regarding speed from FF145 upwards.
Even if you have a Hub2 already getting a second one ensures you have a spare just in case.
Fixes: 334
@bmc I  suspect the OP is on ADSL, with a non-fibre compliant router.
