still having problems
- Full Fibre
- still having problems
05-03-2011 8:10 PM
fttc installed friday 04/03/2011. over 24 hours on, my download speed is half a meg, but upload is fine at 8 meg plus.
Message 1 of 7
(1,731 Views)
6 REPLIES 6
Re: still having problems
06-03-2011 1:24 AM
Have you contacted support to get your IP profile changed for FTTC.
What does a bt speedtest show?
Message 2 of 7
(866 Views)
06-03-2011 10:27 AM
it shows just over 500k download and 8M upload, profile for download is about 38m
Message 3 of 7
(866 Views)
06-03-2011 10:36 AM
dick:green Image tags added.
Message 4 of 7
(866 Views)
06-03-2011 11:53 AM
If https://portal.plus.net/my.html?action=data_transfer_speed does not show 20Mb or 37Mb then you need to ring support and get the plusnet profile set for FTTC.
Until the profile is correct you won't see any change in speeds.
Message 5 of 7
(866 Views)
06-03-2011 1:26 PM
mcn - as per my other reply, now changed (just reboot your netgear - should be fixed).
Message 6 of 7
(866 Views)
06-03-2011 1:36 PM
Message 7 of 7
(866 Views)
