re-contracting on trial
gunsmoke
Hi
I've been off contract for a year or so now.
looking to re-contract, but as I'm still on the trial, does it still work the same way?
should I do it here on the forum, or phone in to the re-contract team?
3 REPLIES 3
HarryB
Fixes: 256
Re: re-contracting on trial
It would be best to give us a call, however if you're on one of the older 100Mbps/300Mbps trials, unfortunately the only options available would be the current fibre products on either 40/2 or 80/20.
 Harry Beesley
gunsmoke
its the 80/20 so no problems there
Spoke to someone over the weekend & all sorted.  He said it would be a hub one they will send out
is that ok for FTTP?
Darkfire
Fixes: 30
Hi Gunsmoke,
Yes the HubOne will work with FTTP, you will need to connect the ONT to the red WAN port on the Hub for it to work
