intermittentSlow speeds since 4th December on MK FTTP
- Full Fibre
- intermittentSlow speeds since 4th December on MK F...
Re: intermittentSlow speeds since 4th December on MK FTTP
26-01-2014 8:48 PM
TAP3 test couldn't find server after changing router username although the IP address and DNS where updated and CHAP authenticated okay to speedtest_domain
At 21:00 tried to run Thinkbroadband speedtest which just got to "stage 2 of 6" and then sat there. Task manager shows zero network traffic there after. Speedtest.net shows a full speed link but takes 4 minutes to load the page before being able to select the test server.
BTW test is now 0.00 download, 18.23 up and 28.75 ping.
Web page loading slow and sometimes needs to be refreshed by F5 key before loading fully as it just "sticks" sometimes. E.G BTW speedtest first attempt froze during the "loading" phase, press F5 and second attempt runs to completion straight away
27-01-2014 9:39 AM
During the problem evenings some web pages will load, others not. When they do I'm often missing several images. Any kind of streaming video (youtube, bbc iplayer etc) or on-line gaming is not usable at all at these times.
Yesterday evening I tried to run the btwholesale speed test but it just got stuck at "loading..." Oddly the speedtest.net site appeared to show a reasonable download speed although the page itself took a couple of attempts to load.
I haven't logged a fault yet but will do if you see some value in it. If there's anything else I can do to help diagnose this issue then let me know.
Thanks,
Herbie
27-01-2014 11:13 AM
Yes please log a fault.
Put in all the details as you have the same issue that I and quite a few others both on PN and BT have. We need the power of numbers to get all the BT owned firms to solve this issue.
We need to pressure the companies into fixing this issue and the only way is for everyone who experiences it is to log a fault and get updating them.
Don't close the call for a least a month as the issue is intermittent and will come back unless PB and BT actually fix the issue rather than just send engineers to house to check the fibre signal is okay. The issue is not with the fibre from the house to the connection point in the street. It is further back up the line somewhere into the exchange and affects MK7 Walnut Tree fttp users.
George
27-01-2014 11:21 AM
Interesting comment on https://community.bt.com/t5/BT-Infinity-Speed-Connection/FTTP-Problems-0-86Mbps-down/m-p/1150554#M12...
User csandbach seems to have diagnosed that the issue maybe network protocol specific .i.e effects TCP packets but not UDP. Might explain why speedtest.net works when the BTW or thinkbroad bands speed test do not.
Have added this to my support ticket too.
George
27-01-2014 11:33 AM
27-01-2014 11:48 AM
Interesting discussions on the bt forums. Will do some more investigating myself next time there are problems and see if I can corroborate the server location / protocol patterns others are seeing. The location thing does make sense, I'm fairly sure speedtest.net selects the MK server for me by default (can't check right now as I'm at work).
27-01-2014 1:00 PM
27-01-2014 3:17 PM
Plusnet Technology
27-01-2014 3:24 PM
Thanks, nice to hear of some progress. Hope this is the issue and that a plan to fix it is quickly implemented.
Looking forward to timely updates and alternatives if this isn't the cause.
George
28-01-2014 9:31 AM
28-01-2014 1:40 PM
When the go slow happens again, then contact them with availability details and then a FOURTH ENGINEER will come a calling.
Of course, the slowdown has only twice exceeded 12 hours and once it reached 24 hours so the chance that the line will still be slow when the engineer arrives in pretty much nil. And of course the slow down starts in the evening so by the time PN book an engineer it will already have been 12 hours or so as getting through by phone at night is impossible and the web ticket may not be read until the day shift turn up at PN.
And what is so special about this FOURTH engineer, well he can talk to the Higher Level Escalation team directly as he has the secret phone number that the other 3 engineers are not allowed.
Today is the 8 (EIGHTH) week anniversary of the start of this issue. Happy 8th week to you.
Disgruntled in MK7
30-01-2014 2:21 PM
Speedtest.net - MK site 76Mbps, London site 7.5Mbps
BTW test shows:
1. Best Effort Test:
Download Speed : 39.34 Mbps
2. Upstream Test:
Upload Speed : 19 Mbps
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
30-01-2014 2:41 PM
Quote The matter has been raised to a high level within BT's Fibre to the Home technical department as well as our own Customer Services. The exchange equipment manufacturers have now been engaged to seek a solution. Unfortunately, we do not have any timescales at present but will keep you updated and will contact you again on Monday 3rd February at the latest.
So it would like a complex problem - or they still do not know the cause exactly.
30-01-2014 2:46 PM
30-01-2014 2:52 PM
I read that post too and assumed the "Or" bit.
I have phoned PN and told them of the latest slowdown. Awaiting a return call for a time slot for an engineer but by the time one gets here the speed will be back to normal as it has been the other 3 times.
@jelv
Well BT Retail sell fttp as a product so it should be stable but it isn't. I actually waited a long time after the trial started before getting it, assuming that the early adaptors would have found the bugs. Wrong!
Thinkbroadband Quality Monitor for past 24 hours
http://www.thinkbroadband.com/ping/share/676c757711be1eb52aa5949c5322e84c-30-01-2014.html
Spot the issue after 2pm.
George
- Full Fibre
