intermittent connection and drop out
tevejulien76f
The wifi the connection is extremely intermittent, if you were to attempt to use this network for a slightly extended period of time, you would find that the connection drops quite often and the speed is a fraction of what is expected.
Attached is photo of the speed test
Is there a problem in the network?
Thank you
2 REPLIES 2
Fixes: 334
Re: intermittent connection and drop out
@tevejulien76f I doubt it is a 'network' issue, more likely an issue on you connection. If you want help from the Community/PlusNet Help Team, I suggest you follow the below ideas:
For Community members to be able to help, information from these two sites, as screenshots:-
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (ethernet) connection, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the HELP DESK tab from your Hub would be a start.
Strat
Fixes: 565
Moderators Note
This topic has been moved from ADSL Broadband to Fibre Broadband.
