incorrect username at install
gunsmoke
Hi
is the FTTP trial using different accounts?
The engineer has just finished connecting the fibre but its not taking my username
I'm still on the f9 if that makes a difference
2 REPLIES 2
gunsmoke
Re: incorrect username at install
sorted!
the auto login on the fibre router didnt set itself up properly.
after a call to PN, its now connected
beeceegee
hey good to see you are up and running at last!
Now if you see any engineers in Hardwick please tell them to get their butts over to Caldecote, where the natives are definitely getting restless  Angry
