fttp keeps dropping
hondaman750
fttp keeps dropping
I have had fiber broadband for a while now but for the last couple of days the connection regularly keeps dropping for a minute or two.Any idea what is causing this,and can someone look into it?
7 REPLIES 7
MatthewWheeler
Fixes: 479
Re: fttp keeps dropping
Sorry to hear you're having issues.
We can see the connection has been dropping but we can't see any cause for this.
It may be worth monitoring it
 Matthew Wheeler
hondaman750
can you let me know if there is anything i can do
Fixes: 1,600
Do you see more drops than indicated below?
If you don't are your devices connecting over WiFi or using a wired connection?
hondaman750
yes i'm sure there have been a couple today, that i have noticed.
and i,m using a wired connection
Fixes: 1,600
Do you notice the light on the front of the router change colour when the connection drops?
hondaman750
to be honest i did not look,next time i'll see what happens on the router
update- just dropped out again but no change on router
Fixes: 1,600
Sounds like the problem may be a bit closer to home, if your router doesn't drop the connection.
Is your computer wired directly to your router using an ethernet cable or going via a powerline adapter?
Do you experience the same problems using a different device?
