fibre speed has dropped since the install earlier today
David3
 Hello
Today I have had my full fibre installed today,the engineer tested and the results  back as full speed 300Mbps down and 48Mbps up
Just got home and done a test myself using  the Speed test app on my phone via the wi-fi the result was 175 Mbps download and 48.3 Mbps upload
Is this due to the fibre connection settling down,I have signed for a 300Mb package,using Hub2 of course and not getting anywhere near the speeds when the engineer came earlier
Or is it a system fault
, I have tested the connection again  with my Lan cable into this computer and the speeds are fine very fast.
So the problem is with  the speed on Wi-fi of my phone,,I'm not that technically minded so bear with me
Appreciate the advice
8 REPLIES 8
Re: fibre speed has dropped since the install earlier today
@David3
"using  the Speed test app on my phone via the wi-fi"
Speed tests via WiFi are rarely reliable - you are testing your WiFi as much as the fibre service.
zpeterk
If you want to test your speed do it with a wired connection to a computer, there are too many variables with wifi
David3
@Anonymous
Hello thank you
 Yes I have just done that ,as per my post I was writing when you replied.I am getting excellent speed with my ethernet cable connected
 Thank you
David3
@zpeterk
Thank you
Yes I kinda guessed and was expecting something amazing.While connected to the wif fi on my phone
But I have tested via my ethernet cable connected  to this computer and the speeds are excellent
SammyM
Fixes: 101
Hiya @David3
I would just tweak the wireless setting to help maximize the wireless connection.
Guides can be found here; Getting the best WiFi (wireless) signal | Help | Plusnet
Let us know how you get on!!
 Sammy M - Sheffield Team
David3
@SammyM
 Hello
Thank you for this ,will have a look,although I am not technically minded.I have tested the speed with my Ethernet cable to this PC and I am getting very fast speeds as expected
I have a Samsung Galaxy A52S  5G phone and while its not old,I suspect the connectivity is not as good as the newer phones
Having tested using the Speedtest app,I am getting mixed results
Thanks again!
Fixes: 524
@David3 i've noticed some very strange things with recent Android 13 & 14 based devices.
Using the speedtest app it maxes out at around 60Mb on both a Lenovo tablet and a fairly new Samung A15. This is on a 900Mb fibre connection! Using a laptop next to the phone gives around 400Mb (as expected) and an older phone running Android 12 gives around 150Mb.
Both the A15 and the tablet seem fast in normal use so I'm baffled as to why they are slow on speedtests. Yes, I know Android 13 & 14 have the capability of a 'throttling' setting for testing apps but I've checked and its set to off! Also checked that both are on 5ghz wifi.
Baffled...
David3
@MisterW
Interesting points raised,thank you
