fibre install
rajivshah24
fibre install
Hi-
I have a  few question on how they install fibre broadband,.
Does the engineer change the line coming into the house?
If the answer to the above is no, could I simply put a new face place on an existing extension and plug the phone and modem into that?
The reason being my master is in an awkward spot and whilst they could use the 30 metre data extension I would prefer not to have new wires running anywhere.
Thanks.
6 REPLIES 6
adamwalker
Fixes: 221
Re: fibre install
The nature of FTTP (fibre to the premises) does mean that a new fibre line is installed into the property so a new data socket would be fitted.
It may be possible to request that the socket (if it's FTTP) is installed in a different location but going via the data extension route would probably be necessary if it was FTTC.
 Adam Walker
rajivshah24
Re: fibre install
Thanks for your response.
To clarify- after the installation I will have both the existing phone line and the new fibre line coming into the property and into the master socket?
adamwalker
Fixes: 221
Re: fibre install
Yes, you should then have two separate sockets, one for data and one for phone.
 Adam Walker
AndyH
Re: fibre install
It's best to have the ONT next to the master socket for when PN offer voice over fibre. Also the internal fibre cable is slightly thicker than normal telephone cable (more like Cat5 thickness), so more visible if run on skirting boards etc.
Also, bare in mind you need a power supply for the ONT (which also comes with a battery backup).
Here's a pic of my ONT/fibre termination box:
itsme
Re: fibre install
Voice over Fibre is that ever going to happen? For a start I thought that the country should be reducing the power consumption not increasing it.
I prefer the good old copper line telephone, it does not add to my electricity bill and it still work when there is a power cut.
AndyH
Re: fibre install
Quote from: itsme
BT already offer it. I think the delay was something due to the OFCOM intervention over the potential power cut issue.
Most people use DECT phones these days any days, most of which don't work with power cuts (which are a rare in the UK) either.
