edit
rubix1942
edit
Engineer now coming to fix fault with line, so kindly delete thread.
5 REPLIES 5
Fixes: 389
Re: Nothing but problems after problems since I signed up
Difficult to answer your question, @rubix1942 without a bit more data, so I'll post my check-list below. Up to you if you follow it, but without some data to work on, Community members will be unable to assist.
For Community members to be able to help, information from these two sites, as screenshots:-
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (ethernet) connection. Please report the 'ADDITIONAL DIAGNOSTICS', and sight of the HELP DESK tab from your Hub would be a start.
If phone test is OK then take the front off your telephone master socket, you may need to remove two screws. In behind you will find the test socket. Plug a filter in here and connect that to your hub. If it’s still dropping out then report a fault at https://faults.plus.net.
Fixes: 389
The edit being a complete deletion - interesting.
rubix1942
I now have another engineer coming some fault with the line apparantly, so wanted to delete the thread but couldn't see how i could so just edited.
If you can delete it then please do so.  Hopefully this 3rd engineer can sort the problems out.
Fixes: 389
@rubix1942 - OK, but it would possibly been of some help if you had posted a short explanation.
rubix1942
OK, It was just born of frustration, so hopefully this will be the fix...finally.
