You are not connected to the internet
FIXED- Subscribe to RSS Feed
- Full Fibre
- You are not connected to the internet
24-03-2020 9:08 PM
I’m experiencing random (what appear to be) disconnects from the internet.
Speed tests and pings come back fine (both Wi-Fi and wired) however it takes AGES for a website to respond. Loading bbc.co.uk will take in excess of 10 seconds to load, yet once I have that connection, it responds like I’d expect it to.
Just trying to access this forum resulted in a ‘you’re not connected to the internet’ message. After 8 refreshes, it starts to load, takes ages but is fine once loaded.
I’ve attached a couple of images showing what I’m experiencing.
Any advice would be greatly appreciated. It’s doing my nut in!!
Fixed! Go to the fix.
Re: You are not connected to the internet
01-04-2020 4:08 PM
Thanks for getting in touch @PDT and apologies for the delayed response.
I've tested your line and I can't see any issues remotely.
If you're still having issues can you try logging into the router when this happens and let us know if you're able to?
11-04-2020 1:13 PM
Yes, I’m still experiencing an issue. Contacted support and they’ve sent me a new router out but it still persists. Once connected to a web site, it’s fine but it takes an age to get the connection - and this is where I get a ‘you’re not connected to the internet’ issues.
03-05-2020 10:35 PM
So, finally resolved this.
In the end, I swapped out the standard Plusnet One hub with a Ubiquiti USG Pro. With everything plugged into a dumb switch, the issue disappeared instantly. Guessing as I had around 10 ethernet connections (via a switch) to the router, it couldn't route traffic successfully.
I'm made up!!
- Full Fibre
