Yes or No to Full Fibre?
khaled35
This option (FTTC) has recently been made available in my area and I was hoping to get the consensus of the people that already have it.
Is it as stable as regular fibre, being my main concern.
16 REPLIES 16
Fixes: 334
Re: Yes or No to Full Fibre?
@khaled35 Once connected, it should be more stable.
Fixes: 530
This option (FTTC
@khaled35  FTTC is not Full fibre , is that a typo ?
FTTP is Full fibre
Fixes: 334
OOOps, @MisterW , missed that, multi answering is not my strong point, and I'm juggling a few topics. Embarrassed
khaled35
FTTC is what's available in my area, and on most checkers, including Plusnet's, it's shown as full fibre.
Edited to add: That's what the person at plusnet said it was - FTTC
Fixes: 334
That is FTTP - not FTTC.
khaled35
See the edit to my previous message. I'm just parroting what I was told and what I wrote down.
So, it's FTTP - that will probably explain the engineer visit.
Question still open for opinions.
Fixes: 334
The advisor at PN was wrong - it is FTTP and will involve connection work.
My answer re: reliability still stands.
RealAleMadrid
Fixes: 66
@jab1  And higher speeds if that's what you want.🤗
Fixes: 334
True, @RealAleMadrid . Unfortunately, at current build schedules I'm three years away, but not really bothered - my 40/10 FTTC is quite adequate for my current, and probably future, needs.
Fixes: 89
@khaled35
If the PN website lets you order, then FTTP is available. However, you can see for yourself. Use the following
Full Fibre shows up as WBC FTTP in the left hand column. FTTC shows as VDSL
If you post a screen image of the results (hidng your details but including the narrative below the results window) we can advise on speed.
khaled35
There we go.
Fixes: 459
@khaled35
So the answer is that both services are avaialble. FTTP is the latest technology, will be more stable, depending on your budget, can be much faster and will be more reliable. It is your best bet.
On the downside you may have to wait a bit longer for it to be installed and you will not have a fixed landline.
khaled35
I just placed my order for the upgrade. I'm not concerned about losing the landline and I've got an engineer install on 12th January. Not that much of a wait, thankfully.
Fixes: 89
@khaled35
Thanks for the image.
You'e one of the few lucky people to have both servies available - and a decent FTTC to boot.
You've already placed your order so it's a bit late to say that FT36 and FF78 are available along with higher speeds.
You should get near your chosen speed with a much lower ping time (if that matters). The narrative indicates no problems are expected with the install (which isn't to say a problem won't be found on the day).
