WiFi Passwords
OldFrank
WiFi Passwords
Hello.
Do i have to use different passwords for the 2.4 Ghz band and the 5 Ghz band ????. can anyone advise me please.
26 REPLIES 26
Fixes: 384
Re: WiFi Passwords
No - use the same password for both.
OldFrank
Re: WiFi Passwords
Hello.
When i try using the same password on the 5 Ghz band nothing will connect, laptop, mobile phones, firestick. They will only connect to the 2.4 Ghz band.
Fixes: 384
Re: WiFi Passwords
Are any of those items 5Ghz capable?
OldFrank
Re: WiFi Passwords
Hello.
Yes they are all 5 Ghz capable.
Fixes: 384
Re: WiFi Passwords
Very strange, because the advice I gave is the standard one - from people with more experience in these matters than me. Have they connected to 5Ghz previously?
OldFrank
Re: WiFi Passwords
Yes they have, but today i have had a lot of problems with my line connection, had to do several resets of my WiFi connection on the hub and the Plusnet techies are monitoring my line overnight. They have raised a ticket on my line problems, just have to wait and see what it is like tomorrow.
Fixes: 384
Re: WiFi Passwords
OK, but note my comment re the password. It helps, BTW, if you give all relevant information when you raise a query.
Fixes: 1,662
Re: WiFi Passwords
Hi @OldFrank
I'm sorry to see you can't connect to the 5GHz wireless band.
Could you find out what firmware your router's on? If you go to your router's settings at http://192.168.1.254 and at the bottom you'll see the 'software version'. Let me know what this says as I suspect you may not be on our latest version.
OldFrank
Re: WiFi Passwords
Hello.
I am on the latest version firmware: 4.7.5.1.83.8.263.
The problem seems to be that the 2.4ghz overrides the 5ghz on all of my devices. my devices can see the 5ghz band but cant connect to it, which is a shame because I am on the 80mbs fibre. The only way to connect to the 5ghz is to disable the 2.4ghz which seems a bit senseless.
Fixes: 384
Re: WiFi Passwords
@OldFrank That is not the latest version, and possibly why you are having these problems. The latest version is .283.1.2 (or even .3, can't remember). Hopefully @Gandalf can get you upgraded.
OldFrank
Re: WiFi Passwords
Thanks for the info about the firmware.
OldFrank
Re: WiFi Passwords
Hello.
My firmware version is: 4.7.5.1.83.8.263
many thanks
Fixes: 1,662
Re: WiFi Passwords
Thanks for getting back to us @OldFrank
Ah that's really odd.
I can see you've posted in the topic Here and we'll update the firmware as soon as we can which should hopefully resolve.
OldFrank
Re: WiFi Passwords
Will that be the same firmware that @bobpullen is pushing out ?? and how long will i have to wait ?Huh
Cheers.
