Why have my speeds dropped???
- Full Fibre
- Why have my speeds dropped???
- « Previous
- 1
- 2
- Next »
Re: Why have my speeds dropped???
15-07-2012 5:20 PM
Quote from: node4 Or is this just a simplified way to class the FTTC 80/20 trial users?
No, it's nothing to do with the 80/20 trial, it's just an "unlimited" value that is a hangover from ADSL2+.
Message 16 of 22
(712 Views)
15-07-2012 10:41 PM
Quote from: Alfred I appear to have the same problem but never reach a speed higher than 38mbps whether on 40/2 pr trial 80/20.
I am told I can't raise a fault if speed is over 12 mbps!
If that is the case -what is the point of having fibre?
So -I will raise a tcket and see what happens!
By the way I am about 700 metres from the fibre cabinet- so that is possibly slowing me down a bit- but BT engineer, when he fitted it, about a month ago, said on normal rate ( up to 40mbps) - I should get about 37mbps- so nothing improved when I went on trial 80/20 other than upload speed - now 6mbps! should my profile be reduced to 20 ( now states 40)?
You are similar to me, I am about 650mtrs from my cabinet, I was getting 38/2 and then switched to the 80/20 trial and I was getting 50/11 but it now seems to be dropping a bit, it was stable at 46/11 but is now at 41/10, over the weekend my profile was changed from 20 to 40 and my speed reduced to 37/10, now reset to 20 and I am back at 42/10
Andrew
Message 17 of 22
(712 Views)
16-07-2012 1:20 AM
Quote from: KevinG
Ah that's fantastic! Just done a quick SpeedTest now - must say I'm rather happy with the upgrade. Plus the pro bolt-on is a fantastic addition to this package - I would recommend it to anyone like me who can't wait for the twilight hours.
Message 18 of 22
(712 Views)
17-07-2012 1:19 AM
how do you manage to get rectangular images of speed tests.
When I copy - I just get the url!
Message 19 of 22
(712 Views)
17-07-2012 7:52 AM
See post below from jelv who explains it better than I did!
Message 20 of 22
(712 Views)
17-07-2012 9:57 AM
It's normal to put the URL between the tags. So Click the Insert Image button (this puts the cursor in the right place) and paste.
You end up with
[img]http://speedtest.net/result/1921886945.png[/img]
which gives you
You end up with
which gives you
Message 21 of 22
(712 Views)
18-07-2012 12:15 AM
Message 22 of 22
(712 Views)
- « Previous
- 1
- 2
- Next »
- Full Fibre
