Why am i only getting 36mbps when i pay for 500mbps
- Full Fibre
- Re: Why am i only getting 36mbps when i pay for 50...
3 weeks ago
I pay for 500mbps but getting 36mbps.
Thanks for any help.
Re: Why am i only getting 36mbps when i pay for 500mbps
3 weeks ago
@Prmiaj are you testing using a wired connection to the router ?
3 weeks ago
3 weeks ago
@Prmiaj Connect an Ethernet cable between your laptop and one of the yellow ports on the Hub.
3 weeks ago
At a guess I think your laptop has connected to the Hub on 2.4GHz rather than 5GHz
If you log into the Hub and browse from >Home >My devices hopefully you will see what frequency the laptop has connected.
Sometimes it's just a mater of disconnecting and reconnecting the laptop WiFi to restore the faster connection.
Depending on the WiFi interface of your laptop you still may not get the 500Mbps you are expecting, my HP laptop only gives me around 320 Mbps on a 900 Mbps connection
3 weeks ago
3 weeks ago
So, have you tried the wired connection, as suggested?
3 weeks ago
3 weeks ago
Also, just a thought, and I don't know if it is even possible for an FTTP connection to work if it isn't - the cable from the ONT is definitely plugged into the WAN port on your router, isn't it?
3 weeks ago
- Full Fibre
