Where to find BBEU or ALID for Plusnet FTTP connections ?
- Full Fibre
- Re: Where to find BBEU or ALID for Plusnet FTTP co...
10-06-2022 2:35 PM
Until the recent introduction of FTTP connections, Plusnet customers wanting to check their broadband BT "IP profile", could use the BT Wholesale Broadband Performance Test , run the basic speed test until done, select [Additional Diagnostic] then enter their Telephone Number and hit the [Run Diagnostic] to perform the test that goes on to show both the upload and download IP Profiles.
For customers who are upgrading to the new Plusnet FTTP service and therefore don't have a telephone number, the BT Wholesale test requires either the BBEU or ALID associated with the connection, in order to proceed.
Where can either the BBEU or ALID information be found in the Plusnet Member Centre ?
Re: Where to find BBEU or ALID for Plusnet FTTP connections ?
10-06-2022 2:40 PM
I got my BBEU by asking on the forum many years ago when I joined the trial. Never seen it on the members centre.
10-06-2022 3:26 PM
@Anonymous I found my BBEU number more or less by accident when looking through the multiple service notes and questions on the account when I signed up to FTTC at my current address, a bit hard to find but I tracked it down!
BT Reference Number set to BBEUxxxxxxxx. BT Circuit Number set to BBEUxxxxxxxx,
10-06-2022 3:34 PM - edited 10-06-2022 3:37 PM
Thanks @SpendLessTime , I thought that might be the case.
As there already forum help requests (such as FTTP upgrade - line training) where the next obvious question is "what does the BT IP profile test show ?", there isn't much point recommending looking at the BT Wholesale Broadband Performance Test if each and every time the customer has to go and ask a Plusnet staff member to provide the BBEU or ALID, because we can't point to where the information SHOULD be found (i.e. in the Member Centre).
Perhaps @JonoH can get the information added ?
maybe here -
https://www.plus.net/member-centre/broadband
or here ?
https://www.plus.net/member-centre/broadband/connection-details
10-06-2022 3:40 PM
e.g. on my line it returns 957.76mbps download profile and 115mbps upload profile.
Interestingly, ~957mbps is pretty much unachievable in terms of DS throughput. Things like PPPoE overheads will knock a good few 10's of mbps off this.
10-06-2022 3:56 PM
From this post on the Sky forums https://helpforum.sky.com/t5/Broadband/How-can-I-obtain-my-Broadband-Service-ID-BBEU-or-Access-Line-... it claims that its available from the BT Wholesale checker using the address
On address checker.
The second screen after you have entered your postcode and capcha, it presents the list of premises to choose.
Look to the end of each address and it shows it there
Certainly there are 2 codes there on my address
10-06-2022 4:03 PM
@bobpullen it might be useful in a case like this one https://community.plus.net/t5/Full-Fibre/FTTP-upgrade-line-training/m-p/1875252#M17492 . The Additional Diagnostic would have (hopefully?) confirmed the incorrect profile
10-06-2022 4:17 PM
Haven't looked into it, but reading that thread I'd be very surprised if it were the BT profile out of kilter. I know there was a defect where, despite the Plusnet profile updating, it wasn't coming into effect until the actual CRM account change was actioned at our side. Suspect that's what happened there.
10-06-2022 4:20 PM
@MisterW wrote:
On address checker.
Look to the end of each address and it shows it thereCertainly there are 2 codes there on my address
I've just tried the two codes listed against my own address, and neither are valid BBEU or ALID values when entered in to the Performance Tester [Advanced Diagnostic] dialog box.
10-06-2022 4:25 PM
Neither of the numbers presented there are my BBEU. I don't have my ALID to hand so can't compare that.
10-06-2022 4:33 PM
The first number appears to be your UPRN - it is for me and can be used on the checker (phone number version).
This is a unique identifer allocated (I believe) by the local authority to a premise after planning permission is granted. It's known to all utility companies and can be used before a Post Code is assigned.
10-06-2022 4:42 PM
Yup, I'd just come to that conclusion.
10-06-2022 4:49 PM
As an aside , in the course of using the Availablilty checker I notice that my exchange is now 'FTTP priority' and the checker returns no ADSl/VDSL available. Looking at the OR stop sell info https://www.openreach.co.uk/cpportal/products/product-withdrawal/stop-sells-updates its in Tranche 4 and went stop sell from 29 April.
I can see me getting queries from the neighbors when they try to move ISP's...
10-06-2022 7:53 PM
Between the two numbers from the Address results I have the letters NS - could this be North Scotland which is consistant with where I live.
If so, this would suggest the second number might be an internal OpenReach identifier.
Neither Mr Google nor Mr DuckDuckGo returned any results on my numbers.
10-06-2022 8:54 PM
very possibly, mine has EM , East midlands would be right for me
- Full Fibre
