Whats happening with the 330mb trial?
- Full Fibre
- Re: Whats happening with the 330mb trial?
08-02-2014 11:48 PM
Hi, dont know if anyone else is/was on the 330mb trial but over the last couple of weeks speed tests have being showing download speeds of around 110mb with upload of around 10mb, as though its reverted back to the 110/10 service. Previously I was getting download speeds that ranged from 150-250 but the upload was always rock solid at 30mb.
I know that the trial is due to end soon but I have had no notification that things have changed so wondered if others are seeing the same change in speeds.
Gary
Gary
Message 1 of 3
(1,232 Views)
2 REPLIES 2
10-02-2014 10:57 AM
I've just made a few checks and nothing on your account or on BT's side of things has been altered as far as I can see so I'd just advise raising a fault as normal: http://faults.plus.net
Adam
Adam
Message 2 of 3
(413 Views)
17-02-2014 10:00 PM
Just found the cause of this, I had turned on QOS on the router and set the values to 100/10 so thats what I got. Just disabled it and now I am getting 150mb plus download and a rock solid 30mb upload.
Message 3 of 3
(413 Views)
- Full Fibre
