What are my chances of being asked to join the trial?
Salopian
I rang support to ask about the FTTP trial and was told that I would be contacted by Plusnet if they wanted me to join.
How are the members selected?
As I only have FTTP available the only way to get fibre speeds is by being on the trial or moving suppliers.
11 REPLIES 11
SpendLessTime
Fixes: 86
Re: What are my chances of being asked to join the trial?
From https://community.plus.net/t5/Fibre-To-The-Premises-trial/Want-to-Join-PlusNet-FTTP-From-BT-FTTP/m-p...
Unfortunately due to the way our signup process works for new customers, we can't setup an account if there isn't ADSL or FTTC showing at www.dslchecker.bt.com
Hopefully in the not too distant future we'll offer FTTP as a full service for new customers as well as existing.
For the time being there's no workaround I'm afraid.
Sorry for any disappointment.
Anoush
SpendLessTime
Fixes: 86
The full list of Openreach FTTP providers offering a commercial product you can sign up to, can be found at
https://www.homeandbusiness.openreach.co.uk/fibre-broadband/ultrafast-broadband/ultrafast-fibre-buy-...
Aspiring Hero
Fixes: 36
Are you currently a PlusNet customer?
If so, you can sign up for the Trial at https://portal.plus.net/wizard/?wizard_id=20 (Note you need to e logged into your PlusNet Members page.
RobPN
Fixes: 13
Support probably know very little about the FTTP trial and it would be unlikely that PN would contact you to join it, rather you would apply to join.
As has been pointed out by @SpendLessTime, you aren't already a PN ADSL/VDSL customer and don't have those services available at your address then you are unable to join through the normal route due to limitations in the PN ordering system.
However there may be a workaround if you were able to become a PN customer by having non-contracted ADSL installed at another address (friends/family?) from which you could then join the FTTP trial by doing a house move to the address you're at which only has FTTP available.  Wink
Salopian
I am curently a Plusnet customer. FTTP is available at my address. I was told that I had ot be invited to the trial. It now appears that I can apply at the link in a previous post.
Why couldn't customer services tell me that?
Strat
Fixes: 565
They're not trained to deal with questions regarding the FTTP trial.
Aspiring Hero
Fixes: 36
@Salopian
Because it's a Trial the service is not integrated with PlusNet back office systems. You can't get PlusNetTV (though you can get the BT Sport app for £5.00pm). It is always best to assume the Call and Live Chat support staff know little if anything about FTTP.
The DSL checker will give a couple of snippets of information about an FTTP install.
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
Apart from having WC FTTP is the left hand column it should state "1 stage" or "2 stage" - this means one visit or two.
There is a narrative after the results. The first paragraph should say something about FTTP like "... feed .... residential property, single premises"
This will have "UG" or "OH" for your phone line and give an indication of any anticipated problems.
Fixes: 1,576
Hi there.
As others have mentioned, the only criteria to join our FTTP trial is that you've got to be an existing broadband customer, and there needs to be WBC FTTP showing as available at www.dslchecker.bt.com
Apologies if you were advised otherwise by our support team.
Once you've raised a ticket at trials.plus.net feel free to drop us a reply back here and we'll take a look.
Anoush
RealAleMadrid
Aspiring Hero
Fixes: 50
@Salopian  Your first post said that only FTTP is available so are you currently on an ADSL service?
The important thing to look for on the checker link that BMC supplied is 'WBC FTTP' in the left hand column not 'FTTP on Demand' which is a stupidly expensive product not offered by PlusNet.
Salopian
What I meant was, I have only the offering of FTTP which Plusnet does not support yet. Plusnet sell FTTC but that is unavaiable to me. The only upgrade is via the trial.
I have WBC FTTP, 2 Stage, OH. so no problems with installing as my neighbours have it with BT.
I have been with Plusnet  for many years.
Aspiring Hero
Fixes: 36
OK - so sign up for the Trial if you wish a faster service and keep an eye on View my Questions in your Members page which is where PlusNet will respond to your ticket.
Two stage means two visits from OR. The first will install the fibre cable from a distribution point to a box to be fitted to the outside of your house. The second will bring the cable indoors and install the ONT for your service.
