Very slow fibre after activation
- Full Fibre
- Very slow fibre after activation
19-06-2014 4:02 PM
Had FTTC activated this morning with very fast speeds reported by the engineer during his setup and test. Actual figures are worse then before intsallation, no matter which speed tester I use the download is never above 0.5Mbps and the Upload is 6-7 Mbps.
Last test using Ookla: Ping = 107ms, Download = 0.45Mbps, Upload = 6.86Mbps.
I have bypassed the Openreach modem and plusnet router with a Draytek router, tried a PC and 2 different laptops (with nothing else on the network) and get the same results.
Surely this cannot be right?
Message 1 of 2
(1,275 Views)
1 REPLY 1
Re: Very slow fibre after activation
19-06-2014 4:07 PM
Your profile was still on its old ADSL value hence the poor speeds
I've just given that a kick for you and if you reboot your router you should see a increase
If you have any further issues please let us know
Message 2 of 2
(336 Views)
- Full Fibre
