Very Inconsistent Fiber speeds
MULSK
Ive experienced really bad performance recently with my mbps as lower than 2.
recently ( a month ago ) went from Fiber to Unlimited Fibre Extra.
Min guaranteed speeds are apparently 41-66 but i am yet to see over 30.
Normally its in the mid 20's
when i check my account on PlusNet
The estimated download range, upload range and min speed state as "not available"
Ive included a speedtest.btwholesale.com test screen shot.
one shows 26.46 and half an hour later another 2.15
Speed tested over Ethernet
Honestly no idea what to do.
I use zoom for work and its too unreliable at the moment.
Any help would be greatly appreciated.
Milo
10 REPLIES 10
Fixes: 388
Re: Very Inconsistent Fiber speeds
Welcome to the forums, @MULSK . Those two speed tests prove you have a massive problem - somewhere.
As you have kindly posted those, can you also post the result of BT Broadband  - obscuring your phone number, your hubs Helpdesk page - obscuring personal details, and the WAN tab of your Event log, please.  This may give us an idea of where the problem are.
MULSK
Fixes: 388
@MULSK From that information, Milo, as far as I can see, you have a BT network issue, as VDSL (fibre) should be stable for a long, long time. Unfortunately, I'm only a Community member without access to any Plusnet data, but now you have posted, hopefully one of the PN Help team will run some tests and if we are lucky, provide the Radius graph and GEA test results, at least.
Unfortunately, you have posted late on a Sunday, so it may be tomorrow before they pick this up.
Wish I could have told you just to reboot the Hub and all would be well, but that will not be the case. Leave everything as it is - DO NOT attempt any reboots/restarts of the Hub, and leave it powered up.
Any more questions and I'll be around until roughly 2130.
MULSK
Thanks John
Its more or less stable at the moment.
So Im not in a mad panic.
But I am looking forward to some one from PN having a look.
Cheers
Fixes: 388
Yup, so am I, Milo - they have better, more comprehensive data sources.😀
Fixes: 480
@MULSK
You are one of the lucky ones with FTTP available. I know that it costs more but why not move into the 21st century and transfer up to that? You will have to leave Plusnet but they will waive the cancellation charges if you talk to them and go to BT or EE.
adam945
Fixes: 113
Really sorry to hear about your poor speeds @MULSK Sad
You're right, the line is syncing well below your MGS - currently coming in at 31.3 Mbps , so the speeds on your devices will likely be in the 20s.
Anyway, I've run some tests on the line from my end and have found a fault with the phone line, and on the broadband service. Given that your broadband pretty much piggybacks on the phone line, I've raised a phone fault with Openreach that we're hoping to have addressed / resolved by 20/10/2021.
If the problems persist with your broadband afterwards, please let us know, though I'm confident that the phone fault being resolved will sort this problem out. Smiley
I've created an open Fault ticket on the account which you can both view and comment on for direct communication with our Technical Support Team here.
KBD
GEA Test Detail
Circuit ID NA Service ID
Test Outcome Fail
Test Outcome Code GTC_FTTC_SERVICE_1613
Description Potential HR Joint detected on GEA service. Please continue to submit a trouble report.
Main Fault Location CE
Sync Status In Sync
Downstream Speed 31.3 Mbps
Upstream Speed 0.7 Mbps
Appointment Required Y
Fault Report Advised Y
NTE Power Status PowerOn
Voice Line Test Result Voice fault suspected - contact Voice CP to progress copper issue
Cross Talk Detected
Estimated Line Length In Metres 563.5
Upstream Rate Assessment Low
Downstream Rate Assessment Low
Technology VDSL
DP Type External
Profile Name 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2021-10-05T08:30:00
Parameters MIN MAX AVG
Down Stream Line Rate 28.8 Mbps 73.6 Mbps 39.9 Mbps
Up Stream Line Rate 0.5 Mbps 15.1 Mbps 4.2 Mbps
Up Time 473.0 Sec 900.0 Sec 899.3 Sec
Retrains 0.0 3.0 0.0
 Adam
 Plusnet Help Team - Leeds
Leapy
Seasoned Champion
@MULSK You have a challenge there with your speeds but I'm confident that @adam945 will get you back to speed soon as the PN guys are great 🙂
It's nice that @jab1 was so supportive too 🙂
However, @Baldrick1  makes a good point for the future, that's worth considering at some stage.
MULSK
So everything looks to be resolved, my internet is speeding along.
Thanks everyone and the PN team for a quick response.
Cheers
Fixes: 1,665
Excellent! Thanks for the confirmation @MULSK
Let us know if there's anything else you'd need help with.
