Use TP-Link Archer C2300 with Plusnet Hub One
- Full Fibre
- Use TP-Link Archer C2300 with Plusnet Hub One
13-01-2022 6:04 PM
I'm looking for some assistance setting up a TP-Link Archer C2300 router with my Plusnet fibre connection.
I have followed the set up instructions that came with the TP-Link router and connected the WAN port to a LAN port on the Plusnet Hub One.
I have a choice of internet connection 'type' including Dynamic, Static, PPPoE and PPPoA.
I have selected PPPoE and entered my broadband dsl username using [email protected] and the same password used to log into the Member Centre yet I'm still failing to get an internet connection.
Please advise if I have missed anything or suggest an alternative configuration.
Re: Use TP-Link Archer C2300 with Plusnet Hub One
13-01-2022 6:40 PM
That configuration is not going to work, the Hub one is already making the PPPoE connection.
In order to suggest an alternative config , what functionality of the C2300 are you wanting to use ?
BTW if this is a new connection, do you really have a Hub one and not a Hub two ?
13-01-2022 7:11 PM
I'm trying to set up the TP-Link router in router mode and not AP mode.
There is an option to use the Dynamic Internet connection type, which does allow me an Internet connection on the TP-Link router, it is being assigned a WAN IP address from the 192.168.1.0/24 address space from the Plusnet Hub and router whilst the LAN is using 192.168.0.0/24 with DHCP enabled. I'm guessing this set up will use double NAT which I wanted to avoid.
I'm trying to understand why the PPPoE option is there if I cannot use it considering this model doesn't have an integrated VDSL modem. Would I be able to use it with an external VDSL modem with the PPPoE Internet connection type option?
It's not a new connection, and I'm using a Plusnet Hub One.
Thanks for the help.
13-01-2022 7:20 PM
The PPOE option is there for you to use when connected to a modem, not a router.
If you want to use the Archer in router mode, you would be better getting a modem, or a router that can be used in bridge mode.
13-01-2022 7:38 PM - edited 13-01-2022 7:41 PM
I think @Mustrum just answered that.
Ah! There was a possibility that if it was a new connection , you had a Hub 2, which does support bridge(modem) mode., but I'm afraid the hub 1 doesnt
13-01-2022 8:59 PM
Thanks for the advice guys, I'll invest in an external modem if required.
Take care and enjoy your evening ![]()
- Full Fibre
