Upload speed increase ?
stoaty
Hello all
Some time last year there was a notification from Plusnet of an increase in upload speed. I think we're still stuck firmly at 2mbps on our fttp, should we have been upgraded?
Many thanks
4 REPLIES 4
adamwalker
Fixes: 221
Re: Upload speed increase ?
Hi there, it looks like you're on an old variant of the FTTP trial that was provided on 40/2 speeds. We've no problem upgrading the upstream though. I've just popped an order through for that which should take effect before the end of the day on Monday.
 Adam Walker
stoaty
Thanks so much chap, working great now.
Ditherton
Hello, how can I increase the upload speed of my connection?
Tibzor
Fixes: 25
Hi @Ditherton
Thanks for getting in touch.
Together with our network partners at Openreach we will try to provide you with the best speeds possible. If you feel this is not the case, please raise your speed fault online at faults.plus.net
-Piotr
