Upload speed dreadful for at least two days
stu1892
Morning
Every speed test I've done for two days brings back 0.2/0.3mbs.
This has only been noticed for the last couple of days but the connection has been unstable for a couple of weeks. Possibly since a power cut.
I haven't tried wired yet but I will today.
This is hampering my work and even uploads small file caused my gf to complain and she never notices the issues.
Any help appreciated. I'll be back in touch with the wired result ASAP.
Issues are across devices and SSIDs
Cheers
Stu
12 REPLIES 12
stu1892
Re: Upload speed dreadful for at least two days
Just the same with the wired connection.
I have not seen one result go above 0.49.
Cheers
Stu
Fixes: 457
@stu1892
What hub have you got? Are you really on ADSL? What upload speed do you normally get? It is unlikely to exceed 1Mbps on ADSL.  Are you trying to download at the same time as uploading? Are you testing with no background tasks running?
Fixes: 333
@Baldrick1 Looking back on the OPs history, he's on VDSL. I have asked for the post to be moved.
stu1892
Apologies if I've put it in the wrong forum. I've never seen it lower than 4mb. No background tasks. Shutdown other devices etc.
I've since approached the PN twitter support and they can see a fault. Given me a couple of things to try with the test line before I get back to them.
Strat
Fixes: 565
Moderators Note
This topic has been moved from ADSL Broadband to Fibre Broadband.
adam945
Fixes: 113
Hello @stu1892
Thanks a lot for reaching out and I'm really sorry to hear that you're having problems with your service.
Tests on the line have uncovered a fault with the Openreach network, so I've raised a Ticket on your account asking you to do a little troubleshooting before we get it raised with our suppliers. We're asking you to do the troubleshooting as tests indicate that the source of the fault is within or near the customer premise.
Please respond to the open Ticket with dates / times that you'd be available for an engineer visit should the troubleshooting prove unhelpful.
Give me a shout on here once you've responded to the Ticket and I'll get it raised. Smiley
KBD
GEA Test Detail
Circuit ID NA Service ID
Test Outcome Fail
Test Outcome Code GTC_FTTC_SERVICE_1625
Description Impairment in copper joint detected most likely in local network. Please continue to submit a trouble report.
Main Fault Location CE
Sync Status In Sync
Downstream Speed 40.0 Mbps
Upstream Speed 0.5 Mbps
Appointment Required Y
Fault Report Advised Y
NTE Power Status PowerOn
Voice Line Test Result Pass
Cross Talk Not Detected
Estimated Line Length In Metres 681.4
Upstream Rate Assessment Low
Technology VDSL
DP Type External
Profile Name 0.128M-40M Downstream, Error Protection Off - 0.128M-10M Upstream, Error Protection Off
Time Stamp 2021-09-28T16:30:00
Parameters MIN MAX AVG
Down Stream Line Rate 39.9 Mbps 39.9 Mbps 39.9 Mbps
Up Stream Line Rate 0.4 Mbps 6.3 Mbps 1.0 Mbps
Up Time 0.0 Sec 900.0 Sec 897.0 Sec
Retrains 0.0 2.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2021-10-11T15:48:31.567+01:00 2021-10-11T16:03:31.567+01:00
Ingress Code Violation 0 0
Egress Code Violation 0 0
Errored Seconds 1 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
 Adam
 Plusnet Help Team - Leeds
stu1892
Hi @adam945
I've replied to the ticket.
I've also just tried a different RJ11 cable with no luck.
Kind regards
Stu
adam945
Fixes: 113
Great stuff @stu1892
That's been raised for you, hope all goes well on Friday, give us a shout if you need anything else in the meantime. Smiley
 Adam
stu1892
Thanks for your help, Adam.  Fingers crossed.
stu1892
I've updated the ticket.
The broadband is now off entirely.
It was working when the engineer left and it has just disconnected and not come back up after a power cycle.
stu1892
It seems to be working now through the Microfilter.  Doesn't seem happy with the faceplate now.
Fixes: 1,638
Thanks for getting back to us @stu1892
I'm glad to see your broadband's working better through the microfilter.
Keep an eye on it and let us know if there are further issues.
