Upgrading to FTTP
norster
Upgrading to FTTP
I'm considering upgrading to FTTP, but I have my own router. Can I keep using it, or will I need to use Pulusnet's own ?
7 REPLIES 7
Mustrum
Fixes: 81
Re: Upgrading to FTTP
That would depend on the router. Does it have an ethernet WAN interface?
Fixes: 118
@norster
Are you aware you lose your phone line and NUMBER?
SpendLessTime
Fixes: 86
As others have said, you can use your own router but do take the Plusnet one too as it will be useful to setup the line and to avoid Plusnet blaming your equipment if things don't work.
So setup the service using their router, give it a few days to ensure that everything works and then swap out for your own kit. Should problems happen at a later date then at least you can swap back to the Plusnet router to help diagnose things.
norster
Yes it does.
norster
Yes - I am aware, and as we don't use the phone line for anything, happy to lose it.
dazgee1965
I used the PN router for the initial connection then swapped it out for a new router I'd purchased.
I'm not a fan of ISP supplied routers but as others had said it's handy to have a spare just in case.
RealAleMadrid
Fixes: 68
@norster  You say you have your own router, but not what it is, I don't know what FTTP service you are thinking of getting but if it is a higher speed service than your current FTTC there could be problems and your router may not be able to cope with the speeds.
