Upgraded to Unlimited Fibre speed unchanged.
Spectacles
Re: Upgraded to Unlimited Fibre speed unchanged.
The speed with the router plug into the test socket is 35.4 Mbps.
Andrew
Fixes: 1,639
Thanks for getting back to me Andrew.
Looking a lot better! Which suggests there may be an issue with extension wiring or the faceplate. Are you OK to leave your router plugged into the test socket? It'll be perfectly fine to do so as that's where I leave my router at home all the time.
Spectacles
Prefer not to have the cable plugged into the test socket, as this leaves wires inside exposed.
Andrew
198kHz
Fixes: 42
It's 50V DC. No harm will come to anyone or anything.  🙂
BT technician (Retired)
adam945
Fixes: 113
Tests are showing better speeds now @Spectacles, and as @198kHz has pointed out, leaving your router plugged directly into the test socket should pose no issues at all, plenty of people do it all the time. You can however purchase a new faceplate from an electrical store, or get an electrician to put another one on for you if you want.
KBD
GEA Test Detail
Circuit ID NA Service ID
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 40.0 Mbps
Upstream Speed 7.8 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Cross Talk Not Detected
Estimated Line Length In Metres 869.1
Upstream Rate Assessment Very Good
Interference Pattern Regular Interference Observed on Week Days
Service Impact Retrains Observed
Interference Duration Longest Occurrence From04:00to04:15
Interference Location Unknown
Interference Observed In Days 2
Technology VDSL
Current 15Min Bin Retrains 0
Last 15Min Bin Retrains 0
DP Type External
Profile Name 0.128M-40M Downstream, Retransmission Low - 0.128M-10M Upstream, Error Protection Off
Time Stamp 2021-11-08T23:15:00
Parameters MIN MAX AVG
Down Stream Line Rate 39.9 Mbps 39.9 Mbps 39.9 Mbps
Up Stream Line Rate 7.6 Mbps 7.7 Mbps 7.7 Mbps
Up Time 861.0 Sec 900.0 Sec 899.2 Sec
Retrains 0.0 1.0 0.0
 Adam
 Plusnet Help Team - Leeds
