Upgraded from 500 to 900
Djkirk
Re: Upgraded from 500 to 900
I phoned Plusnet they told me line will go live after midnight tonight fingers crossed lol
oxytonesam
Ok, I disconnected and reconnected. Hasn't changed anything. I'm guessing this is something I'll have to go directly to support for then
Fixes: 526
'fraid so!.
Djkirk
After being told my speed will increase after midnight still no increase this morning still on 500 instead of 900
SammyM
Fixes: 101
Hiya @Djkirk
I have checked your order and it is showing as complete and I'm sorry you are seeing no difference in speed.
Was the speed test run on a wired or wireless connection?
 Sammy M - Sheffield Team
SammyM
Fixes: 101
@oxytonesam, I have adjusted yours, can you reboot the router and let me know if the speed has increased?
oxytonesam
Thanks for the reply, I've rebooted it from the web ui and I have not seen a change. I find it strange the download speed has not changed but the upload speed has
Djkirk
Wired
Djkirk
All working today 900mb download
Djkirk
I take its taking about 4 days to switch
