Upgrade options from fttp trial?
JakTheBiscuit
I am currently on the FTTP trial with limit of 60GB per month.
I may want to upgrade to unlimited usage but I don't want to lose speed.  What are the options and prices?  The main site does not seem to offer upgrade paths relevant to me.
Plusnet feel free to send me a private message or create a support ticket for me.
J
4 REPLIES 4
HarryB
Fixes: 256
Re: Upgrade options from fttp trial?
Apologies for the delayed response Jack, I want to discuss this with a colleague before giving a definitive answer on this and unfortunately they're out of the office until tomorrow.
Please leave this with me for now and I'll get back to you tomorrow.
 Harry Beesley
HarryB
Fixes: 256
If you were wanting to upgrade to an unlimited usage package and keep the same speeds, I believe it would have to be on 'Unlimited Fibre Extra' at £19.99 per month.
If you'd want to go ahead with this, feel free to respond here or drop me a pm and I'll get that arranged for you.
 Harry Beesley
JakTheBiscuit
Hi Harry, is that a definite answer?  Your "I believe" sounds as though it isn't.
I have an open question about this, Ticket ID 114952793 .
Thanks.
mav:quote
HarryB
Fixes: 256
Technically, the first response you received to the ticket was correct.
As you are on the FTTP Trial you can upgrade to the Unlimited Packages however the speed would be restricted in line with the Products so in the Example of Unlimited Fibre it would be up to 40Mb down and up to 2Mb up and with Unlimited Fibre Extra up to 78Mb down and up to 20Mb up.
To upgrade you would need to speak with the helpdesk as there is quite a lot of 'behind the scenes' changes that would need to be applied to your account for this to progress without issue.
However, as you're on the older FTTP trials, I'd be able to sort something out to retain/restore the higher speeds after you upgrade. Since the speeds you're on are higher than what we offer, I'd only do this on the higher package.
The rest of the responses on the ticket you've mentioned seem pretty poor, so I'll be passing on some feedback about that.
EDIT: I've also now responded to the ticket on your account.
 Harry Beesley
