Upgrade Regret
HumphreyGokart
Upgrade Regret
Hi all, been with  Plusnet for at least 5 years or more FTTC copper line with hardly a glitch got the near enough speeds i was paying betwwen 60 70mbs. Quie happy.
About 2 weeks ago I upgraded to full fibre 300 FTTP Ok first week between 280 to 290 speeds then 2cnd week nternet shut down for 2 hours, came back on speeds still ok, then yesterday Saturday internet went of from 11 am until about 7 pm when it came back on speeds of between 15 and 20 mbs, when I phoned about this a lady answered asked all these questions etc then was told it's up to the engineres when they can fix it, this is unaceptable to me so can i cancel my contract for failure of Plusnet to fulfill there obligations? £34,99 a month for rubish.
8 REPLIES 8
Fixes: 385
Re: Upgrade Regret
@HumphreyGokart When you 'lost connection', what happened with the lights on the ONT?
The lady was correct - it is up to the Openreach engineers when they can fix it - Plusnet only have the option of reporting the fault, and then it is up to OR when they can schedule an investigation.
No, you cannot cancel your contract on those grounds - you must allow time for the fault to be fixed.
Re: Upgrade Regret
It is recommended to perform speed tests using a wired connection to a LAN port those speeds suggest a wireless 2.4GHz connection.
If you check the Hub Two Home >My networks you will see details of how the devices are connected 2.4 or 5GHz.
Fixes: 249
Re: Upgrade Regret
FTTP data test speeds not as expected
There have been numerous reports of measured data speeds not fulfilling users' expectations of their shiny new FTTP service. An end-to-end data speed test is a somewhat blunt instrument with which to test the connection speed. In most instances the FTTP service is running at the product's connection speed, but the user's environment or the data speed test service cannot make full use of (saturate) the FTTP connection's bandwidth.
We can no longer have confidence that the cause of slower-than-expected data transfer speed is due to the broadband connection's performance. If there is any doubt that the user's technology, infrastructure or chosen test service cannot make full use of the FTTP link's bandwidth, then a data speed test is likely to deliver misleading results.
Here are a few things to consider / investigate...
  1. Is the ethernet cable between the router and the ONT (Optical Network Terminator) CAT5e or better?
    CAT5 or below will not transfer data faster than 100mbps thus a simple cable could be the cause of slow data speeds. The ethernet link rate between hub and ONT can be observed in the Hub Two GUI under 'Status'. This is a good indicator of router <> ONT cable function.
  2. Is the device on which the data speed test is being run connected over (CAT5e) ethernet cable (not WiFi)?
    A device connected over 2.4GHz WiFi absolutely will not get anywhere close to 300mbps. It will typically be less than 100mbps. Typical 'good' 5GHz performance using the Hub Two is likely to be below 500mbps and will get lower the further away the device is from the router. More optimal Wi-Fi performance is possible but involves sourcing your own third-party equipment that is capable of the newer standards. Also Wi-Fi performance is equally dependent on the type of device and the age of its technology standards. Some older devices do not support 5GHz, even the most recent smartphones only have a 2x2 antenna array, which limits the number of concurrent Wi-Fi streams. The Plusnet Hub Two can use more streams (go faster), but most types of device cannot.
  3. Is the device on which the data speed test is being run connected over (CAT5e) ethernet cable with no intermediary devices (like Powerline adapters, switches and physical ports) on the LAN side?
    Irrespective of cabling, if there is a 10/100 ethernet switch in the chain then it is going to bottleneck things. Similarly Powerline adapters are highly unlikely to be able to pull anywhere close to 300mbps through electrical wiring. Many Powerline adapters that are rated at e.g. 500mbps, actually have only 10/100 ethernet ports which means the advertised speeds are near fiction.
  4. There are no other devices active on the network at the time of the test.
    Other concurrent use of the network will reduce the bandwidth available for the data speed test, thus delivering a misleading result.
  5. If on a static IP or using the Plusnet firewall (configured in the user portal) has the Plusnet IP profile updated?
    Data speed tests performed soon after the service has been connected (but before Plusnet's systems have updated) might be constrained by the account's line speed profile. Disconnect the router from the ONT, wait a short while, reconnect then check that the Current Line Speed (Download) reported in PN Broadband Status reflects the FTTP product's profile.
  6. If using a third party router ensure that QoS (Quality of Service) and other traffic shaping tools are disabled.
    QoS and other tools have been seen to cause havoc with attempting to saturate FTTP links. Prioritisation and QoS features are very processor intensive and can (probably will) significantly bottleneck speeds. Notably there have been numerous reports of Netgear Orbi maxing out at 550mbps when connected direct to the ONT, rather than being connected to a Plusnet Hub Two.
  7. Is the test device configured to use any VPN or corporate intranet connection?
    VPNs and corporate intranets can also be potential bottlenecks.
  8. Is the data speed test device capable of moving the data at FTTP speeds?
    Some kit simply does not have the power to make full use of FTTP connection speeds. Whilst undertaking data speed tests, if running on MS Windows, use Task Manager's performance tab to check throughput limitations do not arise from...
    • CPU performance
    • Disk read/write speeds - FTTP will easily outpace a 5400 rpm disk
    • Memory utilisation - the data has to go somewhere!
    • Network performance - unless the machine is reasonably new, the ethernet port will be limited to 100mbps!!
  9. Speed test service
    Not all speed test services are dependable nor consistent, so run some comparable tests on different speed test services, at different times of day and night (both on and off-peak) where possible. The following are good points of reference.
Please check out the above factors, to ensure that the perceived data speed is not compromised by some other factor limiting the data throughput-speed of your full-fibre FTTP.
A user has observed that different devices ran at different speeds and their problem was discovered to be the LAN card settings on their Laptop...
My PlayStation was connecting at around 535mbs all the time, but the laptop was only running about 130mbps max. On checking the internet settings I found that speed and duplex were set to auto. I changed this to 1 Gigabit and now the test speed is 838mbps.
To find the settings for your ethernet adapter, go to advanced after selecting properties.
Marsh
Fixes: 41
Re: Upgrade Regret
Hey @HumphreyGokart,
I hope you're doing alright this morning. I tried to call you as we have had an update from our Suppliers, and I just wanted to run through a couple of checks with you. However, I failed to reach you when you're free. Please give our Technical team a call at 0330 123 9123.
Josh
HumphreyGokart
Re: Upgrade Regret
hi John, the lights on the ONT showed 2 solid green lights but no activity 3rd light router has detected a fault,
Fixes: 385
Re: Upgrade Regret
@HumphreyGokart Two green lights - which two? And no red light?
HumphreyGokart
Re: Upgrade Regret
Hi John, It seems that Plusnet has rectified its self and can't understand what the glitch was, still not happy that it went of for about 8 hours but many thank's for all your help and replies.
HumphreyGokart
Re: Upgrade Regret
Hi, it seems that my internet has rectified itself and there is no need for me to phone.
many thank's
