Unreliable internet every night for a couple of weeks.
- Full Fibre
- Unreliable internet every night for a couple of we...
27-09-2021 11:29 PM
Plusnet,
Whats going on? - We've had no connection hiccups for YEARS. Just recently the lady of the house made a change to our subscription and this seems to have coincided with the start of unreliable internet every night from 10pm(ish) onwards.
Pings timeout or take way longer than normal. The router can't be reached, the internet can't be reached, DNS lookups fail, websites time out. Images don't download, even facebook keeps telling me i'm currently offline.
Would you please tell me why there has been a very sudden change?
About a week ago the router (Hubone) could not reconnect to you at all for hours. I gave up and went to bed and by morning it was back again but I want to know why you have suddenly become so unreliable that for the first time in years, i'm having to reach out and grumble.
Please would you just fix it.
7.
Re: Unreliable internet every night for a couple of weeks.
28-09-2021 8:22 AM
Could be on its way out.
28-09-2021 10:55 AM
Probably a couple of years however gien that the problems only happen at night I would be surprised if it was at fault - although this is the 4th or 5th replacement as the others kept doing odd things.
But like i said, this has all started since the boss changed the package and it only happens late at night.
28-09-2021 11:36 AM
Hi @7up, thanks for getting in touch and I'm sorry to hear you've bee seeing connection issues as of recent. I can confirm when testing your connection from this side we can see the drop out you mentioned happening a week or so ago where the connection was lost for a few hours shown by the graph below.
As seen on the above graph we only saw one instance of the connection dropping like it did and it looks to have remained solid since then. If you've been seeing issues into the evening recently then as out testing isn't picking up any underlying issues or errors I beleive the problems you're experiencing are being caused by wireless or wireless interference. It could be that there's been a recent change with a neighbours router or similar which is behind the interference in the evenings and I'd recommend going through the below steps on how best to optimise the wireless settings to best suit your property and surrounding area which hopefully helps moving forwards.
The guide below will show you how to log into the router and change the wireless channel as it's usually another router in the area on the same or similar channel that will be causing issues for both wireless frequencies. Before picking a channel I'd suggest downloading a free app called wifi analyzer (blue and white icon) on the android store which will scan your area for all the routers and show what channels they are on between 1-13. Although the above app isn't essential it helps you pick where your router would be best in terms of channels and saves a lot of time doing it via trial and error.
1) To connect to your Hub One, you will need to open a browser and go to 192.168.1.254 If you have any issues doing this via Wireless, we recommend trying to do it via Ethernet cable instead.
2) You should come to a page with information about your connection, click 'Advanced Settings' at the top and it will ask you to sign in with a Password. This is located on the back of your router under 'Admin Password'
3) Select the option for 'Wireless' followed by '5 GHz Wireless'. What we want to do to begin with is turn 'Sync with 2.4 GHz Wireless' to 'Off' and update the SSID to be different. The easiest way would be to add '-5G' to the end so it is identified as its own connection. Once this is changed, we will need to keep an eye on it for a day or 2 to see if the issue continues. If it does, the next step would be to change the wireless channel. Keeping in mind the original 2.4Ghz unchanged name network connection would be the best to connect your devices to for a stronger signal.
(When deciding which device goes on what frequency keep in mind that the 5GHz is designed for close range stationary devices and standard 2.4GHz the one which gets the wireless around your property further.)
4) Following the above guide to get to your 'Advanced Settings' page, you will need to change the settings within the 2.4 GHz Wireless tab and the 5 GHz Wireless tab.
5) Under the correct heading, you will need to find 'Channel Selection' on the list and change this from 'Automatic' to any one of the other channels, This can also need doing under '5 GHz Wireless' to cover both signals. Give it 3-4 hours of testing to see if the issue still persists and try to change the channel again if you see little or no improvement.
Let us know how it goes and if the issues look to persist.
- Full Fibre
