Unify UDR7
contiva
Unify UDR7
Full Fibre installation and I am trying to connect a Unify UDR 7 router direct to plusnet but the PPoE settings arent working
My installer says I dont need the plusnet hub2 at all, never mind in bridge mode (says he does this a few times a month)
He has used the following to try and set up the UDR7
<myusername>@plusdsl.net along with the password I use to connect to the plusnet portal
It doesnt connect at all
Any ideas? he's adamant he doesnt need the hub2 at all in bridge mode
any advice appreciated
thanks
4 REPLIES 4
Fixes: 585
Re: Unify UDR7
@contiva He's correct, just connect the UDR WAN port directly to the ONT
Make sure you havent got VLAN tagging enabled
I'm not familiar with the UDR, is there any log file to indicate why the PPPoE connection may be failing ?
Just checking, does the connection work if you use the Hub 2 ?
Fixes: 387
Re: Unify UDR7
@contiva Must admit I don't know why it doesn't work - your settings all look correct to me. Your installer is correct, you do not need the Hub2 - the ONT is the modem.
Sorry if this  doesn't help much, but I'm wondering if it something in the UDR7's settings - I have no idea, as I  haven't got one, but hopefully someone with more knowledge will be along.
contiva
Re: Unify UDR7
all sorted - had to use a manual DNS entry rather than auto
Fixes: 585
Re: Unify UDR7
@contiva does the UDR try to ping the DNS server as a connectivity test by any chance ?
The Plusnet DNS servers won't respond to ping
