Underwhelming FTTP switch from FTTC
Nimos
I went live yesterday with FTTP Full Fibre 500 upgrading from Unlimited Fibre Extra (64 - 72Mbps). Using Plusnet Hub Two shipped to me.
I read that it can take 14 days to settle and you need to power cycle the router each morning (done this morning), but what should I expect in the first few days?
I'm getting 65ish down and 56ish up. The openreach engineer was getting mixed results on tests where it occassionally showed 500 down and 75 up but I'm not getting close.
I'm also finding requests take a long time to transact (clicking web links) but fast to download when they respond.
My Products page on plusnet dashboard is still showing my old product also.
Any thoughts appreciated.
Thanks,
S.
11 REPLIES 11
Fixes: 585
Re: Underwhelming FTTP switch from FTTC
there is no training period on FTTP
that's not right. Sounds like your product change hasn't completed, that may be why your speed is not right, especially if you have a static IP
Fixes: 118
@Nimos
You don't need to power re-cycle your router wach day - just leave it on.
Nimos
Should it have changed when it went live or have lag? Less than 24 hours since switch.
Fixes: 585
The account change should normally happen by the end of the day of install.
Fixes: 118
@Nimos
It should change automatically I believe but PN systems have been known to fail on this.
You either need to wait for a staff bod to pick up on this thread or phone support.
Nimos
I've just had PN support sort it for me. My product hadn't changed because the Openreach engineer visit had been brought forward from the 15th Dec and something didn't work on the automated switch.
Seems to be a bit quicker now and said it should speed up over the next hour. Thanks for the replies. Much appreciated.
willcutforth
Fixes: 113
Hey there @Nimos just checking to see everything is still working smoothly for you? Let me know either way.
 Will Cutforth
Nimos
Partially resolved. My product listing on the portal is now correct but the speed down is still significantly lower than 500 at 92Mbps. Upload is fine at 73Mbps. Am testing on LAN connection with a fast PC.THe other issue is I am getting streaming time-outs intermittently.
S.
pjmarsh
Fixes: 24
The first thing I'd check is the ethernet cables between the ONT and router, and router and machine you're testing on (and any others between).  They would need to be at least CAT5e.  I've heard of some cheap CAT5e cables not working to standard either though.
Next I'd check that the ethernet ports your using are actually running at 1Gb rather than 100Mb.
Nimos
Looks like it was a network cable issue. Just plugged in using a cable from the router box and have got 425 Mbps down. 🙂
willcutforth
Fixes: 113
Awesome glad it's resolved @Nimos do you need anything else from me?
 Will Cutforth
