Unable to enable static IP
kjwkjw
I am back in the Plusnet fold after 2 years away due to lack of FTTP back then!
Now re-activated on fibre 900 as of yesterday but the static IP option is not letting me change from Dynamic to Static...
Anyone else had this issue, and is there a fix?
Thanks in advance Smiley
3 REPLIES 3
Fixes: 1,662
Re: Unable to enable static IP
Welcome back @kjwkjw
I tried to fix but didn't have much luck, so I've removed and re-added the static IP add-on.
If you can turn your router off and on or do a single disconnect/reconnect within your router's interface, you'll be on a static IP. I've also credited your account with £5 to cover the duplicate charge as a result of this.
Let me know if there are any issues. Smiley
kjwkjw
Thats great, thank you very much! Looks better in the portal now.
I`ll reset the session once work is over! Smiley
Is there a panel for rdns setup or is that an email to someone?
Thanks again.
MatthewWheeler
Fixes: 503
Hi @kjwkjw
If you can drop me a PM with what you want the rDNS set to I'll get that raised for you
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
