Unable to connect my samsung Smart TV to new fibre router (Wirelessly)
nedster
I've just had my fibre installed and changed over the router to the Technicolor 582 fibre router. My Samsung TV will not connect to the router wirelessly but does using an ethernet connection. Everything was fine with the old router.
Does anyone have any suggestions on how to resolve this and get it back connecting via a wireless connection?
12 REPLIES 12
tonycollinet
Re: Unable to connect my samsung Smart TV to new fibre router (Wirelessly)
I'm going to suggest the obvious - just in case. Have you updated the ssid and security settings in the Tv?
nedster
Hi Tony,
Yes. It finds  the router no problem. I then enter my key exactly as it shows. It seraches for a min then comes up saying connection failed.
tonycollinet
OK - I'd try
1 - removing security in the router (just short term as a test)
2 - Check the security type (WEP/WPA) matches what you had previously.
3 - that works, try re-enabling and using a simpler key
JHewess
I had something similar happen once on an old Samsung blu-ray player while trying to connect to the Be Thompson router. The way I got around it was to configure the connection on the player manually (assign an ip etc) rather than rely on DHCP. It's a bit of a faff, but worth a shot perhaps?
nedster
Hi Tony,
Are you able to give me some  further details on each of the points?
tonycollinet
Probably not
Currently in Germany with limited web access.
Hopefully someone else can help in the short term
taras
What is the model of the sammy tv?
nedster
Hi Taras,
The Model is UE50ES6300
nedster
Eventually solved this . Samsung and Plusnet both very unhelpful to be honest! What I did was go into the router settings and delete the MAC address for the TV. I then went through the install  wireless procedure again on the TV and it has installed without any hassles whatsoever.
Chris
Legend
Fixes: 169
Hi nedster
Sorry we couldn't be of more help on this, unfortunately there are so many devices out there we have to draw the line with supporting them somewhere. Good to hear you got it working and removing the device from the router was a good idea.
w23
Fixes: 4
Quote from: nedster
That could be a useful step for anyone having connection issues with virtually any device, maybe one for support to all to their standard list since it's a router setting rather than a device setting.
Quote from: Chris
@Chris, see above...  Wink
Call me 'w23'
tijara33
Fixes: 6
My Samsung UE40H 7000 last night lost its connection on my 2.4 Ghz network & point blank refused to reconnect. For some odd reason it is now happily connected to my 5 Ghz network & working better than ever. Bl***y computers! Roll_eyes
