Trials!
bongobeanie
Trials!
How do I get on them?
5 REPLIES 5
jelv
Fixes: 10
Re: Trials!
Does the BT Number checker say FTTP (not FTTPoD) is available to you?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
MattyC
Fixes: 46
Re: Trials!
If so, then it's trials.plus.net
HarryB
Fixes: 256
Re: Trials!
Welcome to the community forums @bongobeanie
Unfortunately it doesn't look like WBC FTTP is available for you Sad
Only FTTPoD, which is not covered by the trials and we wouldn't be able to provide.
 Harry Beesley
bongobeanie
Re: Trials!
Can you let me know when fibre will be available? We are about ten yards from the box!
HarryB
Fixes: 256
Re: Trials!
The best advice I can give for that is keeping an eye on the Openreach website Here.
When FTTC or FTTP is available, you'll also be able to see the availability at dslchecker.bt.com
FTTC Will show as VDSL and FTTP would be WBC FTTP.
I hope this helps.
 Harry Beesley
