Terrible fibre speeds, any suggestions?
elostirion
Results from BT Wholesale performance test:
Download speedachieved during the test was - 2.94 Mbps
For your connection, the acceptable range of speedsis 16 Mbps-76.8 Mbps .
Additional Information:
IP Profile for your line is - 76.8 Mbps
Upload speed achieved during the test was - 7.52Mbps
Disconnecting from the router and reconnecting after a few minutes improved the upload speed but not the download.
(Ticket #69952245)
5 REPLIES 5
James
Re: Terrible fibre speeds, any suggestions?
Hi Giles,
Can you so a soft disconnect/reconnect and try again please?
elostirion
James,
Not at home at the moment, will try again this evening.
James
It's basically how we had your line profiled.  I've amended that so there should be an issue when you get home.
elostirion
Thanks James, working fine now (74 down, 19 up)  :).
Giles.
adamwalker
Fixes: 217
Good to hear, thanks for letting us know.
Adam
 Adam Walker
