Switching from FTTC to FTTP - Fixed IP
robkgee
Hi
I'm about to have the switch over to Full Fibre. Does anyone know if I'm going to be able to keep my current fixed IP address from my Fibre Broadband account?
Tags (2)
36 REPLIES 36
Fixes: 117
Re: Switching from FTTC to FTTP - Fixed IP
@robkgee
If it's a straight upgrade then your Static IP should remain the same. I would, however, keep an eye on it when FTTP goes live.
plusmouse
@bmc and @robkgee : What`s a fixed Static IP?
RealAleMadrid
Fixes: 68
@plusmouse  It's a fixed WAN address that your router uses to connect to the internet. Can be useful if you are running any sort of server or you need to get access to your local network when away from your home.
Fixes: 117
@plusmouse
Most ISP users have a "dymanic" IP address which can (and does) change. If your connection goes down for a while (say a power cut or you simply switch off the equipment for some reason) then when you re-connect to PN you would be allocated the next available IP address from the "pool" of numbers that is used by PN.
If, as previously stated, you want to know the IP address at all times to be able to connection to your router from an external location you can get a static (fixed) address.
With PN it costs a one off payment of £5.00.
plusmouse
@RealAleMadrid  and @bmc - Thanks for explaining that. I`ll have a Dynamic IP as won`t require a Static one!
Boz
@bmc - what does it cost to change from FTTC to FTTP?  My contract with Plusnet is coming up for renewal soon, and I wondered whether this was a good time to upgrade.
Boz
Fixes: 117
@Boz
First thing to do is to confirm that FTTP is available to you. Look at the following
You're looking for WBC FTTP is the left hand column and Available over to the right. If it's available there will also be a narrative below the results window which will state if any install problems are expected.
If it's available then you can upgrade at any time at the cost of a new contract and losing your landline if you still have one.
Boz
Many thanks for the link, Brian.
It threw up a lot of interesting data about usage etc. on my telephone/broadband.  I didn’t see WBC FTTP in the left-hand column, but under Featured Products there was “FTTP on demand” and the word “Available” under the “Availability Date” column. However, at the end of the table of stats, there were some comments, including: “FTTP is not available” and “the exchange is not in a current fibre priority programme”.  I’m using fibre at the moment, so it does seem odd to see that last comment.
Anyway, thanks once again for your help.
Boz
Fixes: 382
@Boz 'FTTP on Demand' is a very expensive product, only really suitable for a business with very deep pockets.
Fixes: 117
@Boz
In a victory for the marketing people over common sense FTTC is called Fibre while FTTP is called Full Fibre.
As stated FTTP on Demand is a expensive product not supplied by PN.
Your choice now depends on your landline phone usage. If you want to keep a phone serice you can phone PN and get your contract renewed as an as is basis ie phone and internet. If you're not bothered by your landline or are happy to move to VOIP you can move to a SOGEA connection which is internet only.
Boz
Hi Brian
Thanks again for your comments - you seem to know a lot about this topic!
I suppose that everyone who wants an economical digital landline will have no choice but to move to VOIP.  Do you happen to know how soon it will be before Plusnet start to terminate analogue landline contracts?
Boz
Fixes: 117
@Boz
Most of what I know is from this Forum alongside technical news pages.
Wholesale Line Rentals (WLR - which is for the phone) are being terminated on the 31st December 2025 by BT Wholesale (who market the OpenReach products) except in exceptional cases.
I expect PN will give 3 months notice once a decision is taken as to when they pull the plug.
As with any service you'll get low and high priced VOIP products from various independant providers along with ISP's who offer both VOIP and Internet. It just depends on what you want from a digital phone service.
Boz
Hi Brian
Sorry to resurrect this topic again, but I was recently advised by Plusnet that Full Fibre was now available to me.  Not believing this, I used the Broadband Availability link you gave me; and sure enough the wording has changed to FTTP is available.
I don't understand this because nothing physical has changed at the property, so there must still be a length of copper cable being used, and therefore not fibre-to-the-premises!!  Could you please advise. VMTs.
By the way, what does ONT mean in this context?
Boz
Fixes: 382
@Boz Nothing physical will change at the property until you order FTTP. When the order is accepted PN will place an order with OpenReach who will arrange for an engineer to come and install the fibre cable to your property and disconnect your copper 'last mile' - from the street cab to your home.
ONT means Optical Network Terminal, which is in effect the 'master socket' for the new service.
