Stupid question maybe
Jwatson
I want to upgrade to full fibre. There is only one socket available however. Can I use an extension for the equipment?
5 REPLIES 5
Fixes: 1,495
Re: Stupid question maybe
The engineer will install a new ONT in your house, the phone socket will no longer be used.
You can discuss with the engineer where you would like the ONT placing and if it's reasonable they should accomadate that.
Champnet
Fixes: 21
The question seems to be about power supply….
Fixes: 1,495
Oops. Could always situate the ont near more sockets then 🤣
Fixes: 479
There shouldn’t be a problem using a mains adapter or extension lead.
Jwatson
