Stuck on 40/2 profile - what has happened - or hasn't??
- Full Fibre
- Stuck on 40/2 profile - what has happened - or has...
- « Previous
- Next »
Re: Stuck on 40/2 profile - what has happened - or hasn't??
01-05-2012 8:04 PM
01-05-2012 8:32 PM
I'd make sure you raise your issue as a question on the website. You tend to get more sense than ringing up.
01-05-2012 9:55 PM
The faults team are supposed to be looking at my connection now so I hope we can get to the bottom of the issue. As you say at least my connection is as solid as ever at the standard 40/2 speeds.
01-05-2012 11:02 PM
01-05-2012 11:34 PM
After trying a few things, it was eventually decided to drop the 80/20 back to 40/2 to fix the profile.
The regrade to 40/2 did indeed fix the profile, and tonight the regrade back to 80/20 has just gone through
Now got 80/20 working just fine.
As an aside, from personal experience - If the BT/OR Modem is unlocked, you can see the maximum attainable line speed on the webportal of the modem itself. It's not exactly hard to do either.
02-05-2012 10:39 PM
Fingers crossed.
My ping halved from 20ms to 9ms on speedtest.net too.
Dave
02-05-2012 11:20 PM
dick:quote
03-05-2012 7:38 PM
04-05-2012 9:47 AM
Quote "may be too long for higher speeds than 38Mb and 40/2"
06-05-2012 2:49 PM
Conflicting advice from BT, one side says 47 down is the best I can get the other say 33 aarrgghhh!
06-05-2012 4:42 PM
Ticket # 55147079
Profile was wrong then supposedly corrected but still seeing no difference from 40/10.
Thanks!
Mark.
- « Previous
- Next »
- Full Fibre
