Strange Bing Error
kirkstones
Strange Bing Error
Since re-joining PlusNet last week I've started to experience a strange "Bing" related issue.
When searching on Bing I get very limited results. For example a search for "Marvel" returns 8 results. Something is wrong. Google works fine, but I use Bing daily as well.
It's not a end device issue, all devices on my network experience the same problem, phones, laptops and desktops.
I've tried using Google and Cloudflare DNS servers with the same result. Of course I can't change the DNS settings on Hub Two directly.
I've rebooted the router, same result.
I've connected directly to the router via ethernet, same result. If I use mobile data it works fine.
Safeguard is switched off.
Connection speed is perfect and other sites don't appear to be affected
Tracing the route to Bing is flaky . . .
C:\Users\user>tracert www.bing.com
Tracing route to dual-a-0001.a-msedge.net [204.79.197.200]
over a maximum of 30 hops:
  1    <1 ms    <1 ms    <1 ms  192.168.1.254
  2     4 ms     4 ms     4 ms  172.16.14.172
  3     *        *        *     Request timed out.
  4     7 ms     6 ms     7 ms  132.hiper04.sheff.dial.plus.net.uk [195.166.143.132]
  5     8 ms     7 ms     7 ms  peer2-et3-1-4.slough.ukcore.bt.net [62.172.103.220]
  6     8 ms     *        *     ae62-0.ier02.lon04.ntwk.msn.net [104.44.37.125]
  7     *        *        *     Request timed out.
  8    14 ms     7 ms     7 ms  13.104.140.117
  9     *        *        *     Request timed out.
 10     *        *        *     Request timed out.
 11     *        *        *     Request timed out.
 12     7 ms     7 ms     7 ms  a-0001.a-msedge.net [204.79.197.200]
 Any assistance is appreciated.
7 REPLIES 7
kirkstones
Re: Strange Bing Error
I've now tested with a VPN and Bing operates normally, so this is 100% a PlusNet DNS or IP address issue. Please help resolve.
bobpullen
Fixes: 330
That traceroute reaches it's destination so isn't necessarily indicative of a problem. The IP you're going to differs to what I see though (I have no problems using Bing):-
C:\Users\Bob>tracert www.bing.com
Tracing route to dual-a-0001.a-msedge.net [13.107.21.200]
  1    <1 ms    <1 ms    <1 ms  home.gateway [192.168.1.254]
  2     1 ms     1 ms     1 ms  172.16.17.177
  4     8 ms     7 ms     7 ms  132.hiper04.sheff.dial.plus.net.uk [195.166.143.132]
  5     8 ms     8 ms     8 ms  peer3-et-7-0-4.redbus.ukcore.bt.net [62.172.103.252]
  6    11 ms     9 ms    11 ms  ae64-0.lts-96cbe-1a.ntwk.msn.net [104.44.15.134]
  7     8 ms     8 ms     8 ms  13.104.140.156
  8     *        *        *     Request timed out.
  9     8 ms     8 ms     8 ms  13.107.21.200
Trace complete.
Yes you can. You can specify that the DHCP server dish out custom DNS addresses. From memory, I think it's under the IPv4 network configuration in the Hub Manager.
kirkstones
Thanks Bob.
I gave up last night and paid for the fixed IP address - magically the issues melted away, so I'd say it was an IP address issue; perhaps blacklisted with Microsoft or a partner.
This is my trace now:
  2     8 ms     7 ms     7 ms  253.core.plus.net [195.166.130.253]
  3     8 ms     8 ms     8 ms  84.93.253.107
  4     8 ms     8 ms     8 ms  195.99.125.134
  5     8 ms     *        *     peer3-et4-0-5.slough.ukcore.bt.net [194.72.16.238]
  6     *        8 ms     8 ms  ae62-0.ier01.lon04.ntwk.msn.net [104.44.37.123]
  8     9 ms     8 ms     9 ms  13.104.140.118
 10     8 ms     8 ms     9 ms  13.107.21.200
Hadn't seen that setting on the the hub, so thanks for that - much better now.
bobpullen
Fixes: 330
Glad to hear it's sorted.
For posterity, and in case anybody else is experiencing problems and finds this thread, the IP you were assigned at the time began 150.x.x.x I believe.
kirkstones
Annoyingly, the issue has returned.
bobpullen
Fixes: 330
@kirkstones what does your traceroute look like now the problem has returned?
kirkstones
Hello Bob,
Oddly, it's back to normal this morning. I'll continue to monitor the problem and see if it comes back.
